VPN to the inside and then go to the outside
Nov 28th, 2007
I am trying to figure out how to VPN into my network and then from inside my network go out to a certain site with the same ip address. I know it defeats having the whole concept of VPN but the other site will only allow us to access their site from within our network.
dominic.caron Wed, 11/28/2007 - 07:23
If your using ASDM,
Simply go into your vpn group policy and edit it.
in the advance tab, you'll find "split tunneling"
You can tunnel all network or you can create a ACL defining the network you want to be encrypted by the ASA. (destination network)
If you need the how to using CLI, I'll need more time to sort this out. (I usualy manage my VPN asa using ASDM)
