SNMP configuration on ACS appliance
paulkeestra
i'm trying to configure SNMP on an ACS appliance(System configuration => Appliance configuration => SNMP agent). There is also an option "accept SNMP packets from selected hosts". When i enter an IP adress in the "Host Address" field, i receive the following error:
One or more IP addresses are invalid. Use a (,) as a delimiter between IP's. Wildcards are not allowed.
The ip address i'm entering is just in the xxx.xxx.xxx.xxx format. Also tried 2 addresses, with a comma as delimiter, but still the same error.
Has anyone expierenced the same error on an appliance? The software version i'm using is 4.1.4-13
Thanks in advance
aghaznavi
Level 5
Level 5
It's a build in Win SNMP service.
verify the following.
1.SNMP Communities box, enter the community strings for SNMP. With the exception of the comma(,), all characters are valid. You must use a comma (,) separator between community strings.
2.In the Host Addresses box, enter the specific SNMP client host addresses. You must use a comma (,) delimiter between host addresses
