Configure HSRP in a cat 3750 switch
Nov 28th, 2007
What sofware version (ip-base, ip-services, SMI, EMI) I need to configure HSRP in a Catalyst 3750 stack?
Where can I find the differences between each version? I remember a web tool to compare features of each version in the cisco web but I don't fint it now
Overall Rating: 5 (1 ratings)
Nagendra Kumar ... Wed, 11/28/2007 - 03:34
HSRP is supported in c3750 EMI image version.
You can use Feature navigator to check the feature support. (You may need CCO login)
jmprats Wed, 11/28/2007 - 05:27
Thanks, but in the feature navigator I can see HSRP in the ip-base image
andrew.butterworth Wed, 11/28/2007 - 04:35
HSRP is supported in all three images (IP Base, IP Services & Advanced IP Services), You are limited to 32 HSRP instances though.
The main differences between the three versions are:
IP Base Unicast IP routing but support for RIP & Static Routing, IP Services & Advanced IP Services additionally support EIGRP, OSPF & BGP. (12.2(25)SE adds EIGRP Stub to IP Base
IP Base - no Multicast IP inter-VLAN routing (PIM Stub is supported from 12.2(25)SE), IP Services & Advanced IP Services additionally support full Multicast IP routing. All images support IGMP Snooping at layer-2
VRF Lite is supported on the IP Services & Advanced IP Services images, it's not available in the IP Base image.
Advanced IP Services adds IPV6 support.
