Stefano Amici Wed, 11/28/2007 - 03:52
I solved the issue: the SCCP phone on Cisco CallManager for 1.1 must be a 7970 and not 7960 as for 1.0.
nyciscotech Wed, 11/28/2007 - 06:13
According to the Nokia user guide/release notes, it mentions Callmanager should be configured as a S60 (plugin necessary for Callmanager) and for Callmanager express versions it should be configured as a 7970.
Stefano Amici Thu, 11/29/2007 - 08:42
Could you give me the link where i can download the 1.1 release notes and CallManager plugin?
On Nokia site i can find only Intellisync 1.0 user guide and release notes.
Stefano
a.gooding Thu, 11/29/2007 - 08:45
  • Bronze, 100 points or more
anyone ever got the E series working with just the SIP client?
anderson-david Fri, 11/30/2007 - 07:01
Hi Arvind,
I had this confirmed by Cisco that this doesn't work, the only way to get the Nokia phones working was with the Client
I hope this helps
Dave
Stefano Amici Fri, 11/30/2007 - 08:01
Nokia E65 and E61i works in SIP on CCM and CCME while E61 doesn't work.
Stefano
a.gooding Thu, 12/13/2007 - 18:44
guys,
someone previous posted a config to get this working.Thread - http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddedac9/8#selected_message
i never did get it working using SIP.
Anderson i know you said the SIP would not work but im hearing mixed opinions.
anyone have a clear answer and/or config to get this working with teh SIP client?
thanks in advance
jeroenhermans Thu, 12/13/2007 - 23:24
I can confirm The build in SIP client is working on the Nokia E60, E61 and E90 using CUCM 6. Possibly on other eseries devices as well but I have only tested these 3.
These are the settings needed on the Nokia device :
Profile name: CUCM6
Service Profile: IETF
Default Access point: *your wifi access point*
Public user name: sip:[email protected] <= (your [email protected] server address)
Use compression: No
Registration: On demand or Always on
Use security: No
Proxy server
Proxy server address: sip:172.16.10.105 < = (host name CUCM SIP Realm CFG)
Realm: CUC6009941 < = (host name CUCM SIP Realm CFG)
User name: 1000 <= ( your extension, configured in SIP Realm user name)
Password: *your password* <= ( configured in SIP Realm pwd)
Allow loose routing: Yes
Transport Type: UDP
Port:5065
Registrar Server
Registrat serv. addr.: sip:172.16.10.105 < = (host name CUCM SIP Realm CFG)
Transport Type: UDP
Port:5060
CUCM6 CFG
SIP Realm
Realm: CUC6009941
user: 1000
pwd: password
End User Configuration:
UserID=1000
Digest Credentials=password
insert device based on MAC
3rd party basic sip phone
assosiate device
System - Security Profile - Phone Security Profile
Third-party SIP Device (Advanced) - Standard SIP Non-Secure Profile
Third-party SIP Device (Standard) - Standard SIP Non-Secure Profile
enable Enable Digest Authentication and set transport type
security template enable Digest Credentials
Create a new SIP Profile "NOKIA E61 Standard SIP Profile" allowing you to change specific settings
System - Enterprise Parameters: change parameter " ccmsipline" to "CUC6009941" & auto registration from SCCP to SIP
Kind Regards,
Jeroen
a.gooding Fri, 12/14/2007 - 04:22
thanks for the great info. However, you said version 6, we have version 5.1.2(b) currently and was under the impression that it would have worked with this as well.
Note*** Not seeing ccmsipline parameter under ent param.
thanks again
Thucnk_FPT_FIS_6 Mon, 01/07/2008 - 20:24
Hi Jeroen
I am configuring SIP Phone in NOKIA E90 with CCM 6.0. When I add a new Sip Profile, I encounter an error : "Profiles in same realm must have same user name" in NOKIA E90. I checked user name. Everything is OK. I can't save this profile.
Can you tell me the solution for this issue?
Thanks.
jeroenhermans Wed, 01/09/2008 - 02:21
When working with the build in sip client on the Nokia, it is always best to have only 1 profile defined.
So, try and delete all the existing ones you have and only add the one you will use for CCM 6
Rgds,
Jeroen
Paolo Bevilacqua Thu, 01/17/2008 - 07:19
  • Hall of Fame,
    Founding Member
Ivan, send config please ?
ivan.garrido Thu, 01/17/2008 - 07:50
I attach the config, the ephone 11(7940) and ephone 22(Nokia) sharing line 105.
Ivan
interface FastEthernet0/0.20
description Gateway Voz
encapsulation dot1Q 20
--More-- ip address 10.56.1.1 255.255.255.0
h323-gateway voip bind srcaddr 10.56.1.1
tftp-server flash:P00403020214.bin
tftp-server flash:CP7912060000SCCP050124A.sbin
tftp-server flash:apps11.1-0-0-72.sbn
tftp-server flash:cnu11.3-0-0-81.sbn
tftp-server flash:cvm11.7-2-0-66.sbn
tftp-server flash:dsp11.1-0-0-73.sbn
tftp-server flash:jar11.7-2-0-66.sbn
tftp-server flash:SCCP11.7-2-1-0S.loads
tftp-server flash:term11.default.loads
control-plane
voice-port 0/0/0
station-id name FAX CHILE
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
dial-peer voice 540 voip
tone ringback alert-no-PI
destination-pattern *5T
progress_ind setup enable 3
progress_ind progress enable 8
progress_ind connect enable 8
modem passthrough nse codec g711ulaw
session target ipv4:10.1.100.239
dtmf-relay cisco-rtp h245-signal h245-alphanumeric
ip qos dscp cs5 media
no vad
dial-peer voice 541 voip
--More-- tone ringback alert-no-PI
preference 2
session target ipv4:10.1.100.238
no vad
telephony-service
max-ephones 30
max-dn 30
ip source-address 10.56.1.1 port 2000
auto assign 1 to 30
system message LOGICALIS - CHILE
url services http://10.56.0.8/services.asp
user-locale ES
time-zone 18
time-format 24
create cnf-files version-stamp 7960 Jan 11 2008 09:48:07
max-conferences 4 gain -6
web admin system name softnet password softnet
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 1..
transfer-pattern *54...
transfer-pattern *.....
transfer-pattern *......
xmlschema grabacion
--More-- !
ephone-template 1
ephone-dn 11 dual-line
number 105
name CISTERNAS, Pedro
ephone-dn 22 dual-line
number 105
label Nokia E61
description telefono en prueba
name Nokia E61
ephone 11
mac-address 000E.8492.D528
type 7940
button 1:11
ephone 22
description prueba NOKIA
mac-address 0019.790F.AC84
type 7960
button 1:22
line con 0
line aux 0
line vty 0 4
access-class 2 in
privilege level 15
transport input ssh
line vty 5 15
access-class 2 in
privilege level 15
transport input ssh
scheduler allocate 20000 1000
ntp master 1
end
RT-Softnet#
RT-Softnet#sh tele
RT-Softnet#sh telephony-service
CONFIG (Version=3.3)
Version 3.3
Cisco CallManager Express
For on-line documentation please see:
www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/index.htm
max-ephones 30
max-dn 30
dspfarm units 0
dspfarm transcode sessions 0
hunt-group report delay 1 hours
max-redirect 5
user-locale ES
time-format 24
date-format mm-dd-yy
timezone 18 SA Eastern Standard Time
keepalive 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
caller-id name-only: enable
web admin customer name Customer
edit DN through Web: enabled.
edit TIME through web: enabled.
Log (table parameters):
max-size: 150
retain-timer: 15
auto assign 1 to 30
local directory service: enabled.
xml schema grabacion
Paolo Bevilacqua Thu, 01/17/2008 - 09:22
  • Hall of Fame,
    Founding Member
you cut the configuration due to "more". So I don't see two ephones both with button 1:22 as expected.
ivan.garrido Thu, 01/17/2008 - 09:43
Thank you!!
I configured both ephone with button 1:11 and now the sharing line is working fine!!
My mistake was to configure both ephone with diferents button (1:11 and 1:22), but the same number in both button.
Thanks a lot.
Ivan.
