LDAPS over SSLv3
Nov 28th, 2007
I configured ACS to authenticate users from AD Server.
If I enable "Use Secure Authentication" to ldap (ad) server then I does not work.
(Trusted Root CA: I now that I have to set the root certificate)
If I use "Certificate DB Path" cert7.db file then it works.
In fact the way with "Trusted Root CA" use TLSv1 and "Certificate DB Path" use SSLv3.
Is it possible to force SSLv3 in the way of "Trusted Root CA"???
Does it give a registry key somewhere ofr this???
