PRI problem on 3745 IOS 12.3(8)T
sartorio1
Hi.I've a strange problem since a few months ago.
I have four NM - HDV2 - 2 T1/E1 on 3745 with IOS 12.3(8)T.Two of these modules have 1 port (E1 PRI ISDN) works fine (all 30 channels are provided) and the other works bad (5 - 6 channel are available at the same time).
I've tested DSPs on both modules and all 15 DSPs are alive.
Someone can help me?
Thanks for all.
Flavio Sartorio
9 Replies 9
bwilmoth
Level 5
Level 5
check the details using sh voice dsp voice
show voice dsp voice command lists the model of the DSP in use.The DSP NUM lists the number of the DSP. The DSP numbering scheme varies depending on the router platform and the NM in which the DSP is installed. The CH column indicates the DSP channel used for each physical DS0. The number of channels that a DSP can support depends on both the
DSP model and the codec complexity in use
Hi.
I've checked dsp's as you told me and I attach the text file with results.I think dsps are ok.What do you think?
Thanks.
FLavio
Ciao.
MOreover I changed my Cisco 3745 (with problems) with a new one.The same configuration and the same HDv2 at the same positions (new hardware and new hdv2).Nothing changed!Same problem!!!!
I don't know what to think!!!
FLavio
Can you upgrade to 12.4(3j) that is the most stable and try again ?
I'll try and let you know.
Thanks for now.
Flavio Sartorio
Hi.I didn't find IOS 12.4(3j) so I couldn't try it, but I load IOS 12.3(8)T the same we have on the second voice gateway which works ok (VG2).The VG2 has the same hardware configuration as the first one (VG1) that doesn't work correctly.
I "cut and paste" the two -sh version- :
VoiceGW1#sh version
Cisco IOS Software, 3700 Software (C3745-IPVOICE-M), Version 12.3(8)T, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2004 by Cisco Systems, Inc.
Compiled Thu 13-May-04 18:59 by eaarmas
ROM: System Bootstrap, Version 12.3(6r) [cmong 6r], RELEASE SOFTWARE (fc1)
VoiceGW1 uptime is 5 weeks, 10 hours, 48 minutes
System returned to ROM by reload at 00:15:03 MET Tue Mar 4 2008
System restarted at 00:16:00 MET Tue Mar 4 2008
System image file is "slot0:c3745-ipvoice-mz.123-8.T.bin"
Cisco 3745 (R7000) processor (revision 2.0) with 245760K/16384K bytes of memory.
Processor board ID FCZ0940725B
R7000 CPU at 350MHz, Implementation 39, Rev 3.3, 256KB L2, 2048KB L3 Cache
2 FastEthernet interfaces
248 Serial interfaces
8 Channelized E1/PRI ports
DRAM configuration is 64 bits wide with parity disabled.
151K bytes of NVRAM.
31744K bytes of ATA System CompactFlash (Read/Write)
125184K bytes of ATA Slot0 CompactFlash (Read/Write)
VoiceGW2#sh version
ROM: System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
VoiceGW2 uptime is 1 year, 48 weeks, 6 days, 1 hour, 3 minutes
System restarted at 13:52:13 MET Tue May 2 2006
Processor board ID JHY0816K1CJ
I don't understand why the same gateway with the same hardware with the same IOS (now) doesn't work in the same way.
It drives me crazy!!!!!!
Flavio Sartorio
Can you explain again what is that doesn't work and how do you know that doesn't work ?
I have four NM - HDV2 - 2 T1/E1 on 3745 with IOS 12.3(8)T.Two of these modules have 1 port (E1 PRI ISDN) works fine (all 30 channels are provided) and the other works bad (4 - 5 channel are available at the same time).When VG has the 40 calls load (for example), it addresses 28 - 29 calls on PRI works good, 3 - 4 on PRI works bad and the others on PRI we use for back up. when system works fine I expect 20 calls on the Pri 1 and 20 calls on the Pri 2.
Thanks for all.
Flavio Sartorio
Thanks for all.
Flavio Sartorio
