extended ping
Nov 28th, 2007
dear all,
what is the significance of extended ping??
please help me!!
andrew.butterworth Wed, 11/28/2007 - 04:43
It allows you to set optional parameters when issuing a PING, the same goes for an extended traceroute. If your platform supports it you can issue IPX pings as well as IP. See the output below showing you the various options:
Protocol [ip]:
Target IP address:
Repeat count [5]: 100
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: loopback0
Type of service [0]: 184
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 100, 100-byte ICMP Echos to, timeout is 2 seconds:
Packet sent with a source address of
Success rate is 100 percent (100/100), round-trip min/avg/max = 1/3/4 ms
nambi_gct Wed, 11/28/2007 - 05:42
I generally use this to find out where packet fragmentation happens by setting the DF bit.
