dominic.caron Wed, 11/28/2007 - 06:32
  • Silver, 250 points or more
A tunnel is a link between two point. It can be a GRE tunnel (unencrypted) or a VPN tunnel(encrypted) or ... anything that create Point-2-Point link over a public network.
A VPN a create private network over a public network usually with encryption. To use encryption, you need to create tunnels( encrypt in one point, decrypt at the other). You can also have un-encrypted VPN. With MPLS-VPN, you create private network using tagging over you enterprise or service provider network.
Please rate helpful post
veena_kompal Wed, 11/28/2007 - 06:43
Thanks for the relpy. So does this mean IPsec tunnel and VPN tunnel is one and the same?
dominic.caron Wed, 11/28/2007 - 06:47
No,
IPsec tunnel is one kind of VPN tunnel. IPsec is only the encryption technology used.
You can have SSL tunnel and PPTP tunnel...those can also be called VPN.
