ACE: Transparent NAT feasibility
Answered Question
Nov 28th, 2007
Is transparent NAT possible? The applications need to be aware of the source IP address to process. The only way I can see to do this is insert the source into the header. I seem to recall reading about transparent NAT, and no NAT, but I cannot find it now.
All ideas welcome.
Correct Answer by Gilles Dufour about 9 years 1 month ago
BTW, I want to clarify that client nat is not on by default. You must have configure it and if you do so, you lose information about the client ip. The solution to insert the info into the http header is a good one.
Gilles
Overall Rating: 5 (1 ratings)
danger_mousie Thu, 11/29/2007 - 07:01
Have found what I was reading, transparent NAT is for VIP to rserver transparency not source. So I have implemented http header insert with %is.
Correct Answer
Gilles Dufour Fri, 11/30/2007 - 12:55
Gilles
