Hardware 3002 VPN desktop connection issue
Nov 28th, 2007
Customer using a windows xp workstation fails to connect to the domain through the VPN tunnel. appears that the IP traffic is not flowing until a ping is initiated form the host end of the tunnel. The 3002 tunnel connects to the 3015 without any issues, all traffic is tunneled. This is an ethernet connection to an ISP. After the workstation is pinged from the host end the user can then logoff and logon then has domain autthetication and can then get to domain resources.
owillins Wed, 12/05/2007 - 09:08
  • Silver, 250 points or more
disable the ip inspect command on the inside interface and then try again it will work
