mobile voice access - not able to place a call
Nov 28th, 2007
I setup voice mobile access on the CUCM 6.0 and on the h323 gateway. On the gateway I've got a BRI connecting to the PSTN.
I can reach the IVR, but when I try to place a call I immediately get disconnected. Find attached the q931 trace.
Does anyone have an idea why this happens?
Peter
myquick6 Thu, 12/06/2007 - 08:56
Did you ever get this resolved? I have 2 systems setup one works fine and the other has the same issue you have been seeing.
Thanks, JR
robray_sc Tue, 11/25/2008 - 19:03
JR, did you find a fix for this problem. Having the exact same issue. Thanks
