General Questions About WLC 4400 Cluster
Answered Question
Nov 28th, 2007
I've inherited a couple 4402 Wireless LAN Controllers and am in charge of getting them ship-shape. While I have some general knowledge of wireless, I have not worked with wireless controllers before and have a couple questions I was wondering if anyone could help me with:
1) How can I verify that the primary and secondary controllers are configured for failover without actually performing a test? Both do have AP Failback enabled, but I'm not sure what else to check.
2) They are currently running code 3.2.116.21. Should I stick with 3.2 or plan to move up to 4.X?
Thanks a bunch. I'm slowly working my way through the docs and answers to these would sure speed things up.
Correct Answer by rob.huffman about 9 years 1 month ago
Hi Johnny,
Hope things are well with you! The steps required to configure AP Fallback are detailed quite nicely in the attached doc. I would always try to schedule a Maintenance window to test this out rather than not knowing for sure :)
WLAN Controller Failover for Lightweight Access Points Configuration Example
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008064a294.shtml#c4
Now, for your second question, it's likely that you will want to upgrade the WLC to a newer version of code. They have gone through 4.0.x,4.1.x and the newest is 4.2.x. So 3.2 is a fair ways behind. Have a look at the WLC Release Notes;
Cisco 4400 Series Wireless LAN Controllers Release Notes
http://www.cisco.com/en/US/products/ps6366/prod_release_notes_list.html
Hope this helps!
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
rob.huffman Sun, 12/02/2007 - 09:02
Hi Johnny,
Hope this helps!
Rob
johnnylingo Sun, 12/02/2007 - 11:04
Hi Rob,
Thanks for the input. TAC pointed me to the same doc, and after taking all those steps it finally worked after I erased the config on each AP. Sounds like this might be a bug on the 3.2 Controller code (I haven't looked through all the bugs, but do see there plenty of justify moving up to 4.X)
rob.huffman Mon, 12/03/2007 - 06:18
Hi Johnny,
You are most welcome! Glad to help in some very small way :)
Take care,
Rob
johnnylingo Thu, 12/06/2007 - 15:10
Great tip. I had tried to jump up to 4.1 and it gave me an error about the flash memory. This would explain why it failed.
