NAT Trouble
Nov 28th, 2007
Hi, I want to ask to more experimented network admisnitrators about a problem that I am experimenting and I don't know how to solve:
I have a PIX 515E running 6.3(4) IOS and there are 2 networks configured on it:
Outside 192.168.0.0 /24 (security level 0) and Inside 172.21.0.0 /24 (security level 100).
I used without problems the Static command for mappings from Outside to Inside, using a "virtual IP" in the Outside interface for accesing a host located on the Inside LAN.
Now I need to do the same but in the other direction. I need to use a "virtual IP" in the Inside interface for accessing a host located on the Outside network.
IE:
192.168.0.5 --> NAT --> 172.21.0.5 Works O.K.
172.21.0.10 --> NAT --> 192.168.0.10 I need this mapping
Is it possible to do this running this version of IOS? How can I make this NAT mapping work? I tried a lot of things but no one worked, and I don't know where to find more information about this.
Thank you all for your time, and please excuse my very poor english.
Alejandro.
acomiskey Wed, 11/28/2007 - 09:25
  • Green, 3000 points or more
If I understand you correctly you probably have something like this...
static (inside,outside) 192.168.0.5 172.21.0.5 netmask 255.255.255.255
To do a destination nat in the other direction it should be something like this...
static (outside,inside) 172.21.0.10 192.168.0.10 netmask 255.255.255.255
m47r1x_mdma Mon, 12/03/2007 - 07:26
I tried this but did't work. The command is accepted, but the connection to the host can't be established.
The commands I charged were:
access-list INSIDE permit tcp any host 172.21.0.10 eq www
access-group INSIDE in interface inside
Am I making something wrong or it's not supported by my IOS version or firewall?
Thank you for your help!!!
Ale.
srue Mon, 12/03/2007 - 11:54
  • Blue, 1500 points or more
are there other entries in the ACL INSIDE?
what is the output of "show access-list INSIDE"?
are you trying to connect to 172.21.0.10 from an inside host?
have you verified www services are running on 192.168.0.10?
can you ping 192.168.0.10 from the pix?
