ASA 5505 to VPN Client
Overall Rating: 5 (3 ratings)
acomiskey Fri, 11/30/2007 - 08:14
  • Green, 3000 points or more
The default gateway will be the same as the ip assigned to the client by the asa from the vpn client pool.
To have internet access you must enable split tunneling or outside nat.
Split tunnel
group-policy attributes
split-tunnel-policy tunnelspecified
split-tunnel-network-list value split_tunnel
access-list split_tunnel permit ip
Outside NAT (public internet on a stick)
same-security-traffic permit intra-interface
global (outside) 1 interface
nat (outside) 1
Hope that helps. Please rate if it does.
JORGE RODRIGUEZ Sat, 12/01/2007 - 21:21
Adam, thank you for your input, I knew about split tunneling but not about public internet on a stick.. something new learned . I rate you !
Jorge
