Moving Unity Subscribers GSM Wizard Broken
Nov 28th, 2007
Hi I am attempting to move subscribers within the same AD domain the stream files directory is shared on source and target. When I select move the wizard appears and displays the following.
Unexpected error in:frmMain | addUnityServers
Change Extention Range
Remove Agency
Display Name:Jeroen Van Nood...
Required Minimum VersionSHF01-UNIT01
Unexpected error in: frmMain | setNodesSQLStringSHF01-UNIT01
OKJeroen Van Nood Search ResultsSHF01-UNIT01...
Jeroen Van Nood Servers Found.
Unity is 4.0(4)sr1 on both servers.
Windows 2003 platform disk.
GSM is the latest version off Unity tools.
Logged in as unityinstall via terminal services.
Any ideas?
smalkeric Wed, 12/05/2007 - 12:20
Remove the old location objects from the Unity Locations OU.Create new account called UnityAdmin, make this account a Domain Adminonly.The user accounts should have public and db_datareader rights to the UnityDB inSQL.
Run Configmgr database upgrade scripts
