verification on bandwidth consumtion calculation
Answered Question
Nov 28th, 2007
hello
i would like to know if these values (for frame header ) are correct while calculating a per voice bandwidth usage...
for the frame header :
14 bytes for Ethernet L2 headers, including 4 bytes of Frame Check Sequence (FCS) or Cyclic Redundancy Check (CRC) , 8 bytes of preambleand , 12 byte inter-frame gap.
(38bytes total ) .
for ethernet medium.
Correct Answer by vmoopeung about 9 years 2 months ago
18 bytes for Ethernet L2 headers, including 4 bytes of Frame Check Sequence (FCS) or Cyclic Redundancy Check (CRC).
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a0080094ae2.shtml
use bandwidth calculator.
Overall Rating: 5 (1 ratings)
