port 25 redirect setup
kevin.jones1 Wed, 11/28/2007 - 14:27
static (inside,outside) tcp interface 25 10.1.1.1 25 netmask 255.255.255.255
access-list External permit tcp any host outside_interface_ip eq 25 log
access-group External in interface outside
Easy right?
Looks easy enough, however I am not too familiar with the command syntax with the pix firewall... I assume I type in each line as you have it above one line at a time? How would I un-do this if it did not work properly? Where do I insert the IP address which I want the incoming SMTP traffic to go to? Is there a way to set this up using the web interface and not the command prompt?
sbaddipudi Wed, 11/28/2007 - 14:59
Peter,
you could do a no in front of those commands to remove them. There is a GUI interface if you like it -- PDM I think...
Satya
acomiskey Thu, 11/29/2007 - 09:12
  • Green, 3000 points or more
No, it is the ip that you are using to hit from the outside. If you are using the ip off the outside interface then you can do
access-list External permit tcp any host "outside_interface_ip" eq 25
or
access-list External permit tcp any host interface outside eq 25
acomiskey Thu, 11/29/2007 - 10:53
Yes.
static (inside,outside) tcp interface 25 "spam.firewall.ip" 25 netmask 255.255.255.255
