Arg! What is wrong with my super simple dial-in VPN config?
Nov 28th, 2007
I have a very simple dial-in VPN test, which ALMOST works, but not quite
I can connect up with my "testvpn" user just fine, my workstation gets a 192.168.1.240 address from the VPDN pool
but I cannot PING the router 192.168.1.1 or another device that I've got connected on my router's internal 4-port
switch 192.168.1.239
I don't have any access lists (except for the one that defines my inside NAT range)
I suspect that I'm missing one stupid thing...any ideas?
version 12.4
no service pad
service password-encryption
hostname temp192168
boot-start-marker
boot-end-marker
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
no aaa new-model
ip cef
ip domain name xxxxxxxxx.xxx
vpdn enable
vpdn-group 1
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 1
local name CIS
l2tp tunnel password 7
ip mtu adjust
username myuser secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxx
username testvpn password 7 xxxxxxxxxxxxxxxxxxxxxxx
interface Loopback0
description 192.168.255.1 just for internal PING & Telnet test
ip address 192.168.255.1 255.255.255.0
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description WAN link to Internet
ip address xxx.xxx.xxx.23 255.255.255.128
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Virtual-Template1
ip unnumbered FastEthernet0
ip nat inside
peer default ip address pool VPDN
ppp encrypt mppe auto
ppp authentication ms-chap
interface Vlan1
description inside LAN address
ip nat inside
ip local pool VPDN 192.168.1.240 192.168.1.250
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.1
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet4 overload
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
exec-timeout 60 0
login local
transport input telnet ssh
scheduler max-task-time 5000
end
thomasdzubin Wed, 11/28/2007 - 14:25
FYI: here's the Cisco CLI output from a PING of my locally connected device, a PING of my VPN connected workstation, the output from the "show vpdn tunnel" command, the output from the "show caller ip" command, and finally the output of the "show ip route" command. Everything seems normal, so why can't I PING between my VPN-connected workstation and anything on my 192.168.1.x net?
temp192168#ping 192.168.1.239
Sending 5, 100-byte ICMP Echos to 192.168.1.239, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
temp192168#ping 192.168.1.240
Sending 5, 100-byte ICMP Echos to 192.168.1.240, timeout is 2 seconds:
Success rate is 0 percent (0/5)
temp192168#show vpdn tunnel all
%No active L2TP tunnels
PPTP Tunnel Information Total tunnels 1 sessions 1
Tunnel id 7, 1 active sessions
Tunnel state is estabd, time since change 00:00:43
Remote tunnel name is
Internet Address xxx.x.xxx.3, port 2199
Local tunnel name is CIS
Internet Address xxx.x.xxx.23, port 1723
VPDN group: 1
72 packets sent, 96 received, 3741 bytes sent, 5224 received
Last clearing of "show vpdn" counters never
temp192168#show caller ip
Line User IP Address Local Number Remote Number <->
Vi3 testvpn 192.168.1.240 - - in
temp192168#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is xxx.xxx.xxx.1 to network 0.0.0.0
xxx.xxx.xxx.0/25 is subnetted, 1 subnets
C xxx.xxx.xxx.0 is directly connected, FastEthernet4
C 192.168.255.0/24 is directly connected, Loopback0
192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.1.0/24 is directly connected, Vlan1
C 192.168.1.240/32 is directly connected, Virtual-Access3
S* 0.0.0.0/0 [1/0] via xxx.xxx.xxx.1
temp192168#
thomasdzubin Wed, 11/28/2007 - 14:48
Nevermind... I found my error.
Earlier in the day I was working on a different model router (with different interface names) and I put the wrong interface name into my Virtual-Template1 config.
Instead of "ip unnumbered FastEthernet0"
I used "ip unnumbered Vlan1" and it started working!
Too bad I can't rate my own replies, eh?
