CME Shared Line Issue
Answered Question
I've found a few posts were people have posted this same issue - but no resolution has been given yet. The issue is hard to explain so I'll take a shot at it.
Call Manager Express 4.1 - Shared line appearance issue.
Let's say there's a shared line on my Assistant and Executive phone. This shared line is setup as a 'dual-line' and can handle two calls. When a call rings in the shared line rings on both of the phones as expected - Let's say the Executive phone answers this first call. The issue appears when a second call comes in and the first call is still in progress. This second call is then delivered to the Executive phone and the executive has the option to take the call but there is NO indication that a second call is ringing in on the Assistants phone.
Does anyone have a solution for this issue? My only other option is to make the Executive line a single-line and call forward busy to a backup executive line that is another shared line appearance on both the Assistant and Executive phones.
Thanks!
- Nate
Correct Answer by paolo bevilacqua about 9 years 4 months ago
never configure ephone-dn as a single line because you will be unable to do consultive call transfers and ad-hoc conferencing with it. Use "huntstop channel" instead.
To have a shared line present further calls to all phones, the only solution is to configured call forward buys to another extension. This extension is usually configured in overlay with call-waiting (c separator) on the same button.
Correct Answer by Rob Huffman about 9 years 4 months ago
Hi Nate,
I have never figured this one out, but this is the actual design;
Shared Dual Lines
The Cisco Unified CME call-handling model allows only the active ephone of shared dual line DN to receive additional calls. That is, if an ephone is active on a call on a shared DN, other ephones with the same DN will see the DN in use. If a second call is made to the dual-line DN, that call is only presented to the active ephone. The other ephone does not receive any indication of the second call.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/tsp/2.0/developer/guide/tspdev/tspdvovr.html#wp1040490
I think your plan "B" is the way to go!
Sorry man but I hope this helps a little,
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
Rob Huffman Wed, 11/28/2007 - 14:21
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Nate,
Shared Dual Lines
Rob
Correct Answer
paolo bevilacqua Wed, 11/28/2007 - 19:04
  • Hall of Fame,
    Founding Member
Thanks - you were right! I've found another URL that has a nice example.
Scenario 1
Two phones need to have a shared line. When a call is answered on the first phone and a second call comes in to the shared line, you need to have the call ring at second phone with no call waiting on the first.
ephone-dn 1
number 3001
huntstop channel
no huntstop
ephone-dn 2
number 3001
huntstop channel
preference 1
ephone 1
button 1o1,2
ephone 2
button 1o1,2
Scenario 2
Two phones need to have a shared line. When a call is answered on the first phone and a second call comes in to the shared line, you need to have the call ring at second phone with call waiting on the first.
ephone-dn 1
number 3001
huntstop channel
no huntstop
ephone-dn 2
number 3001
huntstop channel
preference 1
ephone 1
button 1c1,2
ephone 2
button 1c1,2
The above info was taken from this URL: http://cciev.wordpress.com/2006/07/26/cme-overlay-vs-overlay-with-call-waiting/
- Nate
