Chavdar_Baramov Mon, 12/03/2007 - 07:03
What you mean by limit the size?
And what by the number?
What is your aim?
Be more specific.
If you want to delete files which are larger than some value you can make a simple batch script to delete all files which mach the criteria.
@FOR %%C IN (*.raw) DO (IF %%~zC GTR 100000 DEL %%C)
This line deletes all raw files larger than 100000 bytes.
You just need to make a batch file with it and schedule to run on some interval.
mford49 Thu, 12/06/2007 - 12:15
I would like to auto delete raw files older then seven days. We are growing fast and this directory is getting very large.
vjemin Tue, 01/08/2008 - 04:56
So, there is no parametar on IPCC administration to configure how many days can .raw file be in folder Desktop_Audio!?
In version 3.X there is such option!
Vlaho
vjemin Tue, 01/08/2008 - 07:56
Hm,
then, I think that I have a problem, because I have .raw files older then 2 months.
Where I can found these parameters on IPCC servers to check why these files are not erased?
andrei.goncalves Thu, 01/10/2008 - 02:31
I'm interested in this too... for me, it's important to keep 1 month of recording, but I just can keep 1 week...
The "extended life time" is not good because I have to click in each recording to set it.
Thanks.
Andrei.
Chavdar_Baramov Thu, 01/10/2008 - 04:27
I wanted to keep all records, but i didn`t find build-in solution. So i created a batch file which converts raws to wavs and stores them.
Probably there is no such easy solution to click somewhere and change raws valid period, but if there is, it will be perfect if someone shares the method.
