Password Recovery on a 3750 Switch
Answered Question
Nov 28th, 2007
I tried to a password recovery on Cisco 3750 switch. I followed all the steps and got to the point where I copied the config.text to the running-config. After this I got the privileg exec mode of the switch. When I tried to configure the switch with a new enable password, I got the following output
switch1# conf t
% Authorisation failed %
Even the show commands do not seem to work
switch1# sh run
switch1# sh ip int brief
Can someone suggest how to get over this issue to reset the password of the switch.
Thanks in advance,
Raj
Correct Answer by andre.ortega about 9 years 5 months ago
Do you need to maintain the configuration? If doesn't need, don't copy the file config.text for running-config. The password recovery finished.
If you need does the following.
Don't copy the file config.text for running-config. Before copy the file config.text for the computer. Open and edit with the notepad (remove the aaa and change the enable password). Then copy the file config.text (that you altered) for the running-config.
Overall Rating: 3 (2 ratings)
Correct Answer
andre.ortega Thu, 11/29/2007 - 09:22
  • Bronze, 100 points or more
  • Participante em Destaque,
    Escolha da Audiência, Maio de 2015
pvzcisco07 Thu, 11/29/2007 - 21:35
Thanks Heaps for you help Andre. I followed your advice and was able to reset the password for the switch successfully.
Raj
