PDM received an error while sending this command.
Nov 28th, 2007
Each time I am using the Cisco PDM Version 3.0(4) with PIX Version 6.3(5) I find that I am connected initially, but when i try to apply any commands, I recieve the following error message :
PDM received an error while sending this command. Click Resend and if the browser
prompt you to verify a new certificate or to provide a username/password, please do so.
some of my teammates use command line, some use PDM to config the firewall. I am not sure if it is caused by PDM location, PDM group.
Is there someway to fix the proble? your help is appreciated. Thanks
