Paolo Bevilacqua Wed, 11/28/2007 - 20:41
  • Hall of Fame,
    Founding Member
Recalling from distant times memory, yes. However do not expect the interface to perform at line rate.
A small L3 switch like the 3560 8-ports woul be better for the job.
anitachoi3 Wed, 11/28/2007 - 21:28
Can I apply the "rate limit" to control the bandwidth of 3rd interface FE?
regards
Paolo Bevilacqua Thu, 11/29/2007 - 05:28
  • Hall of Fame,
    Founding Member
You can probably use traffic shaping instead.
The 4700 runs old IOS and certain features are not available.
anitachoi3 Tue, 12/04/2007 - 08:46
Hi, any example for traffic shaping? we will have 10M bandwidth. 2.5M is for data. Other is for voice. If the data traffic is over 200K (e.g. 2.7M), it will drop.
regards
Paolo Bevilacqua Tue, 12/04/2007 - 09:18
  • Hall of Fame,
    Founding Member
Hi, configure an ACL that defines you data traffic, under interface configure "shape" command with the wanted traffic amount and ACL.
As an appreciation to those providing answers, please rate useful posts with the scrollbox below!
anitachoi3 Tue, 12/04/2007 - 22:03
we check the interface of router, it has " rate-limit" command. it doesn't have shape command. Does it mean that the "rate limit" to be work?
regards
