User Tracking
Nov 28th, 2007
Can't able to get the End Host Table in Cat 6500 series other switches are doing fine, Already updated the Cisco Works to LMS 2.6, CS 3.0.5, CM4.0.9, User Tracking 1.1.1,. Still does not work with the CAT 6500 series. Any ideas regarding this matter?
Thanks...Carl
Joe Clarke Wed, 11/28/2007 - 21:28
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Enable core, corex, and vlad debugging under Campus Manager > Admin > Campus Data Collection > Debugging Options, then run a new Campus Data Collection, and post the resulting ani.log.
cgarcia1971 Sat, 12/01/2007 - 20:43
Hi Mr. Clarke,
Already enable the debug under CM 4.0.9 with the core,corex and vlad debugging.Attach file is the ani.log result after issuing the debugging. Need your update ASAP. Thanx..Carl
Joe Clarke Sat, 12/01/2007 - 22:44
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You are not hitting the obvious problem, so now you will need to enable vmpsadmin debugging under the same location, then run a full User Tracking Acquisition, and post the ut.log. You will also need to include the hostname and IP address of the missing 6500.
