allowing pc to log onto internal domain in dmz
Nov 29th, 2007
Hi all, I have a pc in the dmz, I need to allow it to log onto the domain,
Can anyone tell me what ports I need to open to my domain controllers for this to happen?
Collin Clark Thu, 11/29/2007 - 07:56
A ton of them. Seriously it's too many to still ensure security. Having a server in a DMZ that is a member of the domain is a major security risk. Google Group for windows domain firewall and you should see the problems people have had getting this to work. We tried it once at a customer site, but eventually moved the server inside.
JORGE RODRIGUEZ Thu, 11/29/2007 - 08:09
Carl, whether this link can help or not Im sure it can, we went through this on another thread while back, please refer to it as there are some links also for Domain authentication and ports information . if problems let us know.
kevin.jones1 Thu, 11/29/2007 - 08:21
In situation like this, the best firewall
is a checkpoint firewall because checkpoint
understand microsoft DCOM ports and it knows
how to handle microsoft Domain authentication
so the security is vastly superior than Cisco
pix or asa firewall
if you already have a pix in place, you would
need at minimum:
ldap(s): tcp/udp 636
kerb: tcp/udp 88
ldap(s): tcp/udp 389
dns: tcp/udp 53
wins: tcp/udp 137/138
nbt: netbios, rpc, etc...
Collin Clark Thu, 11/29/2007 - 08:25
I'm not disputing the capabilities of Checkpoint, however the firewall in this case not make it more/less secure, it just makes it easier to configure.
kevin.jones1 Thu, 11/29/2007 - 08:45
the firewall can help in making this more
secure by not opening more ports than necessary.
Checkpoint understands how Microsoft DCOM works.
As you know with Active directory and Exchange
server, DCOM uses random ports. By
understanding how DCOM works, you do not have
to open all ports >1024.
