In Tacacs+ accountingcmd argument not coming
Nov 29th, 2007
I have deplyed acs appliance 1113 with acsver4.1
commands given are
aaa new-model
aaa authentication username-prompt ACS_FAIL_USE_LOCAL_UserID:
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authorization console
aaa authorization config-commands
aaa authorization exec default group tacacs+ local
aaa authorization commands 15 default group tacacs+ local
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
authetication authorixation is done and also works for a part of accounting but it is not showing the cmd and cmd-arg of tacasa+ accounting
the debug aaa accounting is
016097: Nov 29 16:08:45.604 IND: AAA/ACCT/CMD: User manish, Port tty1, Priv 15:
"show running-config <cr>"
016098: Nov 29 16:08:45.604 IND: AAA/ACCT/CMD: Found list "default"
016099: Nov 29 16:08:45.668 IND: AAA/ACCT: user manish, acct type 3 (1816760447)
: Method=tacacs+ (tacacs+)
016100: Nov 29 16:08:46.060 IND: TAC+: (1816760447): received acct response stat
us = SUCCESS
Date Time User-Name Group-Name Caller-Id Acct-Flags elapsed_time service bytes_in bytes_out paks_in paks_out task_id addr NAS-Portname NAS-IP-Address cmd cmd-arg priv-lvl status AAA Server err_msg event-id
11/29/2007 14:43:21 manish Network Administrator 172.16.4.141 stop 137 shell 129 tty6 172.16.4.20 1 DELIVERANCE1
11/29/2007 14:43:35 manish Network Administrator 172.16.4.141 start shell 131 tty6 172.16.4.20 1 DELIVERANCE1
11/29/2007 14:43:39 manish Network Administrator NAS Port re-used 4 131 tty6 172.16.4.20 DELIVERANCE1
11/29/2007 14:46:38 manish Network Administrator 172.16.4.141 start shell 133 tty7 172.16.4.20 1 DELIVERANCE1
11/29/2007 14:46:41 manish Network Administrator NAS Port re-used 3 133 tty7 172.16.4.20 DELIVERANCE1
11/29/2007 14:46:45 manish Network Administrator 172.16.4.141 stop 190 shell 131 tty6 172.16.4.20 1 DELIVERANCE1
11/29/2007 14:50:09 manish Network Administrator 172.16.4.141 start shell 4035 tty1 172.16.4.4 1 DELIVERANCE1
11/29/2007 14:50:24 manish Network Administrator 172.16.4.141 stop 226 shell 133 tty7 172.16.4.20 1 DELIVERANCE1
kevin.jones1 Thu, 11/29/2007 - 08:22
there will a well known bug with version 4.1.
go to cisco and download a patch for it. After
you apply the patch, it will work after that.
Jagdeep Gambhir Thu, 11/29/2007 - 09:08
  • Red, 2250 points or more
This is a known issue, you need to apply patch ACS 4.1.1.23.5 to fix the issue.
Patch for appliance is available on
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-soleng-3des
Patch name : ACS SE 4.1.1.23.5 accumulative patch
Patch for acs windows is availble on
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-win-3des')">http://www.cisco.com/cgi-bin/tablebuild.pl/acs-win-3des<
Patch Name : ACS 4.1.1.23.5 accumulative patch
That should fix the issue,
Jagdeep
Note: If that answers your question, then please mark this thread as resolved, so that others can benefit from it.
manish.gaur Fri, 11/30/2007 - 08:51
I have acs 1113 and swceen is locked so tell me how to update the paches into it
manish.gaur Sun, 12/02/2007 - 22:27
kevin.jones1 ,jagdeep
Hi please tell me hpw to update these paches in cisco appliance 1113 .
manish.gaur Sun, 12/02/2007 - 22:29
the url which you told me is not working can you pelase check it and tell me
