Layer3 design
Nov 29th, 2007
I want to configure the Layer 3 design between the access switches to the distribution switches "routed port". I read alot of documents that recommend this design instead of L2 & STPs loops.
My question is that i have wireless controller with LWAPs, can i use romaing at this layer3 design?
Please guide to a document that use L# roaming.
Thanks in advance
Abd Alqader
Overall Rating: 5 (1 ratings)
andrew.butterworth Thu, 11/29/2007 - 04:32
Yes is the short answer. With LWAPP the AP's create a tunnel to the Wireless controller and the VLANs exist there. Typically the AP's are plugged in anywhere and as long as the DHCP scope that is supporting the VLAN where it is plugged in is configured with the appropriate option the LWAPP AP discovers the Wireless Controller. All Wireless traffic from the AP is tunnelled over the IP network to the controller where it is handled directly by the controller.
The only caveat to this is if you are using HREAP where one SSID maps to a local VLAN from the AP and other SSID's are tunnelled.
