6513 installations
Nov 29th, 2007
Hey everybody,
It's seems like it's that time of day again where i ask a question to aid me in my quest for knowledge - my search for the all-knowing Cisco Oracle!
A simple one today, a customer has asked for an upgraded supervisor memory card and it's been left to me to perform the installation. Having never done one before i was wondering how simple it was. Also i can't seem to get one of the switch fabric modules to sit right *and i don't want to force it) because the handles seem to big, is it just me or is it a common problem. Last, but by no means least i have to install a fan tray (i presume that's what the vertical slot on the side is for) - as i'm not running any supervisor 32's or 720's i was wondering if it was ok to power up the chassis (for diagnostic purposes) without the fan or is this just suicide? Thanks in advance.
Edison Ortiz Sun, 12/02/2007 - 16:25
  • Hall of Fame,
    Founding Member
Based on your post, it sounds like you are running Supervisor II, see the following URL on how to upgrade the DRAM:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Config_Notes/78_12693.html
___________________
You mentioned fabric module, what kind of line card are we dealing with ? 65xx or 67xx ?
Make sure it has the correct connectors in the backplane, don't force it - it should slide in.
___________________
You can replace the fan while the system is operating, don't run the chassis without the fan for a long period of time
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/6000hw/6500_ins/04remrep.htm#wp1088910
