vinoth_g Thu, 11/29/2007 - 06:07
Multicast traffic destined to a multicast MAC address, Only routers enabled multicast routing protocol can be member of this multicast MAC addresses and receive the traffic and do multicast routing. Non-multicast routers will drop the multicast packets at the layer2 itselft.
Thx
carl_townshend Thu, 11/29/2007 - 06:23
how do you enable multicast on the router? does it use a routing protocol ?
vinoth_g Thu, 11/29/2007 - 13:02
Yep, there are various multicast routing protocol. To enable multicast, in the global configuration mode you have to give ip multicast-routing...Rest of the configuration is depend upon the routing protocol you choose
