LMS 3.0 SNMPv2 and SNMPv3
Answered Question
Nov 29th, 2007
Hello, does somebody knows if the two versions can cohabitate ?
Thank in advance
Correct Answer by Joe Clarke about 9 years 6 months ago
Cisco devices that support SNMPv3 are all tri-lingual. LMS, on the other hand, will opt to use SNMPv3 if it is configured. If SNMPv3 fails, LMS apps will NOT fallback to v1/v2c. However, if you choose not to configure SNMPv3 credentials in LMS for a specific device, LMS apps will use the v1/v2c credentials that you configure instead.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Thu, 11/29/2007 - 09:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
