CLID name and number display.
Answered Question
Nov 29th, 2007
I am using a Cisco Call Manger Express. I am trying to get Caller ID to work for inbound calls from the outside. I am getting the incoming number displayed but not the name. I did a debug isdn q931 and it showed the name incoming into the switch but the name is not displayed on the phone. Please tell me how I need to set the phones or trunks to display the name and number if this is even possible with this version of CCM and 7941 phones. Here is the output and version.
Oct 25 11:23:50.495: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0037
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Facility i = 0x9F8B0100A10F02010106072A8648CE1500040A0100
Protocol Profile = Networking Extensions
0xA10F02010106072A8648CE1500040A0100
Component = Invoke component
Invoke Id = 1
Operation = InformationFollowing (calling_name)
Name information in subsequent FACILITY message
Calling Party Number i = 0x2183, '3376548180'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '4500'
Plan:Unknown, Type:Unknown
Oct 25 11:23:50.519: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8037
Oct 25 11:23:50.527: ISDN Se0/0/0:23 Q931: TX -> ALERTING pd = 8 callref = 0x8037
Oct 25 11:23:50.691: ISDN Se0/0/0:23 Q931: RX <- FACILITY pd = 8 callref = 0x0037
Facility i = 0x9F8B0100A117020101020100800F47454E4E55534F204348524953544F
0xA117020101020100800F47454E4E55534F204348524953544F
Invoke Id = 1
Operation = CallingName
Name presentation allowed
Name = GENNUSO CHRISTO
Oct 25 11:24:02.607: ISDN Se0/0/0:23 Q931: TX -> CONNECT pd = 8 callref = 0x8037
Oct 25 11:24:02.631: ISDN Se0/0/0:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x0037
Oct 25 11:24:02.635: ISDN Se0/0/0:23 **ERROR**: call_progress: DEV_CONNECTED VOICE ERROR: Bearer capability not available(0x3A): b channel 0 call id 0x4F
Oct 25 11:24:02.635: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected to 3376548180 N/A
Oct 25 11:24:06.367: ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x0037
Cause i = 0x8090 - Normal call clearing
Oct 25 11:24:06.371: %ISDN-6-DISCONNECT: Interface Serial0/0/0:0 disconnected from 3376548180 , call lasted 3 seconds
Oct 25 11:24:06.371: ISDN Se0/0/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x8037
Oct 25 11:24:06.391: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0037u all
Version
Cisco IOS Software, 2800 Software (C2800NM-IPVOICEK9-M), Version 12.4(11)XJ, RELEASE SOFTWARE (fc1)
Synched to technology version 12.4(11)T
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Cisco 2811 (revision 53.50) with 251904K/10240K bytes of memory.
Voice Services
voice service pots
voice service voip
clid substitute name
clid network-provided
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
h323
h225 timeout tcp call-idle value 1000
h225 timeout setup 30
h225 id-passthru
voice class codec 1
codec preference 1 g711ulaw
voice class h323 1
h225 connect-passthru
Serial Interface
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
no cdp enable
Typical ephone
ephone 7
description John Doe
username "John_Doe"
mac-address 001C.581C.6FE9
speed-dial 1 95551234 label "Office"
paging-dn 30
type 7941
button 1:60
Correct Answer by Paolo Bevilacqua about 9 years 2 months ago
can you try: ¨isdn supp-service name calling¨?
Overall Rating: 5 (1 ratings)
benwsegura Thu, 11/29/2007 - 14:14
Thank you very much for the valuable advice. That resolved the problem. Can you please tell me where this is listed in the Cisco documentation? Being an old Nortel Option series tech I am still trying to learn the Cisco VoIP product line.
Again, THANKS!!
Paolo Bevilacqua Thu, 11/29/2007 - 15:09
Hi, cisco documentation is mainly made of configuration guides and alphabetical command reference, all freely accessible from the support page for the IOS version you are using. So this command would be in the page for "isdn".
Thanks for the nice rating and good luck!
benwsegura Thu, 11/29/2007 - 21:13
Thanks Rob, there are some useful commands in here. I book marked it in my favorites.
Like you I am accustomed to the Nortel and kept looking under the phone programming for a CLID feature similar to CPND. Now I know it is in the trunk programming section, in this case the D channel of the T1 listed as ISDN.
