Not enough flash memory on 2960-8TC-L
andre.harasim
Hi, I have some new 2960-8TC-L and I would like to upgrade them with the following firmware: c2960-lanbasek9-tar.122-25.SEE3.tar but it's not possible because the Min.Flash which is needed has to be 32MB and this is what I have : switch#dir flash:
Directory of flash:/
2 -rwx 1236 Mar 1 1993 01:00:30 +01:00 vlan.dat
3 -rwx 6714 Nov 28 2007 17:13:20 +01:00 config.text
4 -rwx 5 Nov 28 2007 17:13:20 +01:00 private-config.text
5 drwx 512 Mar 1 1993 01:06:54 +01:00 c2960-lanbase-mz.122-35.SE5
27998208 bytes total (19291136 bytes free)
What I found on cisco.com is:
Table 2. Cisco Catalyst 2960 LAN Base Switch Hardware
Description
Specification
Performance
• 16 Gbps switching fabric (Catalyst 2960-8TC-L, Catalyst 2960-24TT-L, Catalyst 2960-24TC-L, Catalyst 2960-48TT-L, Catalyst 2960-48TC-L)
• 32 Gbps switching fabric (Catalyst 2960G-8TC-L, Catalyst 2960G-24TC-L, Catalyst 2960G-48TC-L)
• Forwarding rate based on 64-byte packets:
• Catalyst 2960-8TC-L: 2.7 Mpps
• Catalyst 2960-24TT-L: 6.5 Mpps
• Catalyst 2960-24TC-L: 6.5 Mpps
• Catalyst 2960-48TT-L: 10.1 Mpps
• Catalyst 2960-48TC-L: 10.1 Mpps
• Catalyst 2960G-8TC-L: 11.9 Mpps
• Catalyst 2960G-24TC-L: 35.7 Mpps
• Catalyst 2960G-48TC-L: 39.0 Mpps
• 64 MB DRAM
• 32 MB flash memory
• Configurable up to 8000 MAC addresses
• Configurable up to 255 IGMP groups
• Configurable maximum transmission unit (MTU) of up to 9000 bytes, with a maximum Ethernet frame size of 9018 bytes (Jumbo frames) for bridging on Gigabit Ethernet ports, and up to 1998 bytes for bridging of Multiprotocol Label Switching (MPLS) tagged frames on both 10/100 and 10/100/1000 ports
So why do I only have 28MB totally available?
Thanks for your help,
André
The syntax looks correct other than your missing the "N" in download but I assume that is just a fat finger in the message . Other than that make sure the tar file is exact with what is on the tftp server . If its still a problem you might have to call the tac . As a test you could download the bin file to it and see if it takes it ok then you could delete it after and this would say the tftp function itself is ok . I don't even see SEE3 on the website for the 2960 model you say . you might want try something like this as this is for the 8 port model maybe you downloaded a image for the bigger switches .
c2960-lanbasek9-mz.122-35.SE5.bin
8 Replies 8
glen.grant
I'm not sure why it says 32 , flash is just a storage area. If you have space which you do to add another image it will work fine . All the images are the same for these switches flash wise . I wouldn't hesitate putting it on , the image itself is less than 10 eg in size for the tar file , if you don't need GUI function use the .bin file instead.
hmmm, yes you are right, but my customer would like to use the archive-download procedure by using the .tar file and what I also found at the ios upgrade planner is the declaration: The selections you have made are: Platform: CAT2960
Release: 12.2.25-SEE3 ( ED - Early Deployment )
Software Feature Sets: LAN BASE WITH WEB BASED DEV MGR
Click a link to change a selection
File Download Information
File name Min. Memory
(MB) Min. Flash
(MB) Date Released
c2960-lanbasek9-tar.122-25.SEE3.tar 64 32 23-FEB-2007
I don't know why 32MB are needed but I get an error message while the archive-download is proceeding.
What is the error that you see using the archive command ??? what is the archive syntax that you are using ?
archive dowload-sw/overwrite tftp://ip.ip.ip.ip/c2960-lanbasek9-tar.122-25.SEE3.tar
the error message is:
Error: The image in the archive which would be used to upgrade
Error: system number 1 does not support that particular system.
:-D 'Fat Fingers'!!! Yes, you are right, I double checked all kinds of available releases for the 2960-8TC and the one which I would like to use (c2960-lanbasek9-tar.122-25.SEE3.tar) isn't listed ;-) ... hmmm, but when I'm using the IOS upgrade planner and choose CAT2960 platform I will get my file listed(http://www.cisco.com/cgi-bin/Software/Iosplanner/Planner-tool/iosplanner.cgi?get_crypto=&data_from=&hardware_name=CAT2960&software_name=&release_name=&majorRel=&state=:HW&type=), whatever... I think I have the wrong firmware... tomorrow I will try an other one and I think this will fix my problem! Thanks for your help, I appreciate that! André
You look like you went in under IOS , I always pull it from the lan switch section as they break out the individual models for the switches what images are available. this is what is available under the lan switch section for the 8 port model.
Switches > Cisco Catalyst 2960G-8TC Compact Switch > IOS Software
Select a Release
Find Release
Expand all | Close all
Latest Releases
12.2.40-SE(ED)
All Releases
12.2
12.2SE
12.2.40-SE(ED)
12.2.37-SE1(ED)
12.2.37-SE(ED)
12.2.35-SE5(ED)
12.2.35-SE1(ED)
12.2.35-SE(ED)
#erase flash:
and then tftp the new image
