Copy command;; backup
Answered Question
Nov 29th, 2007
Anyone knows how to perform "copy startup flash://192.168.100.1/teststart" at once. I mean i want to perform this operation in a single line for use in a script. without confirmations and other parameters.
My ultimate purpose is to backup router configuration regulaly.
Thanks in advance.
Correct Answer by davjobidon about 9 years 2 months ago
Try to add the "file prompt quiet" command in configuration mode, you will then disable confirmations.
Overall Rating: 5 (1 ratings)
Correct Answer
davjobidon Thu, 11/29/2007 - 09:13
