Archive Mgmt Permisions
Answered Question
Using ACS I have granted permissions to some clients to view their device configs in Archive Mgmt. Basic Help Desk access PLUS 'Search Config Archive' checked.
The problem is, these permissions allow the client to view 'Out-of-Sync Summary' which does not appear to limit per NDG like other areas of RME. If the client clicks on the Diff icon they can view configs for many devices outside of their assigned NDG.
Is there a way I can deny access to the Out-of-Sync Summary?
Is there another way I can allow a user to view configs limited to a NDG without providing 'Search Config Archive' permissions?
TIA
~Dan
Correct Answer by Joe Clarke about 9 years 4 months ago
There is no workaround.
Symptom:
Even though a department's users have been granted permissions for ONLY their department's equipment in ACS, in RME they can still see the OUT-OF-SYNC screen. If a different department's device is listed on the OUT-OF-SYNC screen, they can look at the different department's configuration (RME>Config Management>Archive Management>Out-of-Sync Summary).
Conditions:
This occurs in RME 4.0.5 integrated with ACS 4.0.x. Any user not granted permission to see Out Of Sync report, can still see all devices in the Out Of Sync Report.
Workaround:
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 11/29/2007 - 09:36
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Funny you should ask about this. My colleague just filed a bug on this yesterday (CSCsl50606). The fix will not be coming until RME 4.2 due out some time in the second quarter of next year.
Correct Answer
Joe Clarke Thu, 11/29/2007 - 09:49
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Symptom:
Conditions:
Workaround:
