IPv6
Edison Ortiz Thu, 11/29/2007 - 10:17
  • Hall of Fame,
    Founding Member
The link-local address (FE80::) is needed there to transport dynamic routing information (OSPFv3 and RIPng) over the frame-relay.
You can find it by typing show ipv6 int brief
hello freind
EdisonOrtiz:do i need it in my Config?i mean the map statments?
2)The requirments says R10 Lo0 sould be part of the EIGRP 100.Can r10 have this interface into EIGRP 100 AND OSPF AREA 0?
ON R10 i have redistribution between ospf 1 and eigrp 100
can i redistribut to ospf 1 2 eigrp as
like eigrp 100 and eigrp 150
10xs a lot
10XS
Edison Ortiz Thu, 11/29/2007 - 10:30
  • Hall of Fame,
    Founding Member
I'm sorry - I'm confused.
Your first query was regarding IPv6 and the second query is regarding IPv4 dynamic routing protocols.
I believe the answer is, whatever you have in the frame-relay ipv6 statement, it won't affect your IPv4 routing protocols.
You need IPv4 frame map statements as well.
__________________________________________
As for this question:
"The requirments says R10 Lo0 sould be part of the EIGRP 100.Can r10 have this interface into EIGRP 100 AND OSPF AREA 0?"
You can have an interface participating on 2 dynamic routing protocols but it's not 'best practice' and often discourage. For Lab work, yeah it's cool to play around with it but never should be done in production.
Edison Ortiz Thu, 11/29/2007 - 10:54
  • Hall of Fame,
    Founding Member
Yes, that should work. It's not mandatory to include a metric value when redistributing into OSPF.
Edison Ortiz Thu, 11/29/2007 - 10:52
  • Hall of Fame,
    Founding Member
You are missing the 'subnets' keyword so redistributed routes into OSPF can be classless.
Also, the metric illustrated is for redistribution into EIGRP.
OSPF only uses one metric
