Can make intervlan configutstion with L2 and L3 switches
ichavarria
I want to deploy a L3 network with L2 network using intervlan confiration beetwin them.
When you say L3 networks, this means you will be deploying IP as L3 routing protocol; therefore you will need a routing device to do the routing between your VLANs.
And these VLANs in turn will be pointing to this router as the gateway using the respective IP address
