AS5800 Card
Nov 29th, 2007
Hi!, I have a AS5800 and I'm thinking of using it for PBX/VoIP setup. Currently it has a 2pcs CT1 card, do I need a specific card for my setup to work?
Paolo Bevilacqua Thu, 11/29/2007 - 11:38
Hi, if the 5800 is not equipped for voice already, it can be very expensive and complex to equipe it to do that, you can conisder as small as a 2801 for just two T1 voice to PBX.
hope this helps, please rate post if it does!
nourisonrugs Thu, 11/29/2007 - 14:04
What do you mean by "not equipped"? my AS5800 has an 2pcs CT1 Card (with 8 CT1 ports per card). Just in case, what are the things that I need to have? Because I want to make use of it.
Paolo Bevilacqua Thu, 11/29/2007 - 15:35
It needs to have DSP for voice. I think can check what do you have with "show diag", "show ver", or "show inventory".
