Connectiong a pair of 4507r's together
I have a identical pair of 4507r with super 2+. For some reason I cannot get a ethernet connection between the two. Physically connecting a Cat 5 cable between the two. I have also tried using the GBIC slots with fiber but no luck. But If I but a put 3560g in between and than there is a connection and I can pass data or voip. What I want to do is feed one 4507r from the other which is connected to our fiber backbone
mvsheik123 Thu, 11/29/2007 - 11:36
using the ehternet between 2 switch ports need Crossover cable. GBIC slots with fiber should work as long as GBIC i/f configured properly and cabling is good.
