When is a rogue an issue?
Nov 29th, 2007
I have a WLC managed by WCS in an Arena Environment. During events we frequently notice rogue AP's which I believe may be causing interference with our devices. How can I tell if a rogue is an issue of concern because I usually look at the amount of dBi it puts out, if they are at -70, -80, or -90 dBi then I consider them a non-issue. Am I correct in my assesment, do I need to be concerned about a rogue if it drops to -60, -50, or even -40 dBi or am I looking at this all wrong?
smalkeric Thu, 12/06/2007 - 14:24
  • Silver, 250 points or more
The rouge AP timeout settings sets after how many minutes it would generate an alert message if a rouge AP is detected. If you change this setting to 0,you would not see the alert messages on the logs.A cleaner implementation of rogue client suppression would send a targeted de-authentication & then prevent future associations from that client.
ericgarnel Fri, 12/07/2007 - 06:41
  • Gold, 750 points or more
Under the WLC | Wireless| 802.11b/g Global Parameters (802.11a too) | Auto RF Dynamic Channel Assignment Algorithm
do you have "Avoid Foreign AP Interference" checked or not?
Disabling it will make RRM ignore the interference. Read the help file under WLC web gui for more details
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
