t1 implementation
Nov 29th, 2007
I cant remember if this is the case or not, but I have a customer that has a t1 to another remote site. They are adding another remote site, so my question is this: when adding another remote site, do you have to have another t1 at the main site, or does it just join in to the existing t1?
Overall Rating: 4 (1 ratings)
Collin Clark Thu, 11/29/2007 - 11:55
  • Purple, 4500 points or more
Assuming the T1's are point to point , then yes each 'site' will require it's own t1 circuit and t1 interface.
HTH and please rate.
Richard Burts Thu, 11/29/2007 - 11:57
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
John
The answer to your question depends a bit on how the T1 is provisioned. If the T1 is a Frame Relay connection then it is possible for 1 T1 at the head end or HQ site to connect to multiple remote sites. If the T1 is provisioned as a regular leased line (HDLC or PPP) then a second site requires a second T1 connection.
Rick
jjoseph01 Thu, 11/29/2007 - 12:09
Rick, thanks. Thats what I thought, but wanted to verify.
