Sporatic one way audio
Nov 29th, 2007
We have a new install that we are having an issue with occasional one way audio. From what I can tell the issue only happens with occasional incoming calls. There have been no reported issues with outgoing calls. I have verified that each of the pots lines attached to the router is able to recieve calls. I have implemented the voice rtp send-recv command. One symptom that I noticed that could be an issue is if the phone is answered on a half ring (from the pstn callers perspective)...Does anyone have any ideas...here is the config for the voice ports:
voice-port 0/0/0
connection plar XXXXXXX
impedance complex1
description Connection to XXX-XXX-1222
voice-port 0/0/1
impedance complex1
description Connection to XXX-XXX-5410
voice-port 0/0/2
impedance complex1
description Connection to XXX-XXX-5615
voice-port 0/0/3
impedance complex1
description Connection to XXX-XXX-5829
voice-port 0/2/0
impedance complex1
description Connection to XXX-XXX-1715
voice-port 0/2/1
impedance complex1
description Connection to XXX-XXX-2707
caller-id enable
voice-port 0/2/2
shutdown
voice-port 0/2/3
shutdown
Joe
