Configure VPN on Router
Nov 29th, 2007
I have the VPN configured on the the "corp" router and it works fine. How do I also allow clients on the inside of the corp router to use the vpn client to connect to other routers?
JORGE RODRIGUEZ Thu, 11/29/2007 - 21:11
Hi Chris, you need to allow the ipsec or pptp vpn ports and apply acl to your outbound interface facing internet.
e.g.
If using Cisco VPN client it needs UDP 500, UDP 4500 and protocol ESP.
access-list 101 permit udp any any eq 500 log
access-list 101 permit udp any any eq 4500 log
access-list 101 permit esp any any log
Interface Serial0/0
ip access-group 101 in
if using Microsft PPTP vpn client you need to allow tcp 1732 and protocol GRE.
access-list 101 permit tcp any any eq 1723 log
access-list 101 permit gre any any log
Interface Serial0/0
If using both vpn clients combine the acl 101 together and apply it to outbound interface.
This will allow your inside users to be able to vpn outbound to to the outside world.
pls rate any helpful posts !
Rgds
Jorge
