3560 8 port switch for training lab
Answered Question
Nov 29th, 2007
I read a post that said this would make a good switch. I tried to find the enterprise version of this switch for sale, but I can not find the part #. Am I missing something?
Correct Answer by ccbootcamp about 9 years 3 months ago
Nope, no license key to install it. Will it physically work? Yes. Legally? You better check that out with your local Cisco account team. :)
-brad
www.ccbootcamp.com
(please rate the post!)
No, you're not missing anything. The only 3560 8-port switch part # is:
WS-C3560-8PC-S
Which comes with the standard version of IOS. If you have a CCO account, you can download the enhanced version and it will run on the 3560 8-port switch.
Disclaimer: You should check with your local Cisco AM to make sure you purchase the proper licensing to make it legit.
ttyl,
-Brad
www.ccbootcamp.com
Overall Rating: 4.3 (4 ratings)
Correct Answer
ccbootcamp Thu, 11/29/2007 - 13:12
WS-C3560-8PC-S
ttyl,
-Brad
www.ccbootcamp.com
SteveDexter Thu, 11/29/2007 - 14:03
Do I need any type of license key to get the enhanced version to run on the 3560 8-port switch? If I am using it for a lab environment, will it work?
Correct Answer
ccbootcamp Thu, 11/29/2007 - 14:21
-brad
www.ccbootcamp.com
