7911 - Idle URL file format
Nov 29th, 2007
I've been able insert custom background for the user to choose, in 7911 (Cisco Call Manager 5.1.2).
I would like too to use Idle URL Option, but i dont know how to do it (ive been able to put idle url background with sdk in 7940-60-70 series, but it is not working with 7911, giving me always XML Error(5)).
Can you help me please?
hadbou Thu, 12/06/2007 - 14:30
It is possilbe that you are using any of these special characters becasuse there is a note in the following link stating that
Special characters cannot be parsed correctly and return an error to the IP phone. Some of these special characters are ( & " ' < > ). Avoid use of these characters in the naming convention for your users.
metalium2007 Thu, 12/06/2007 - 14:32
Sorry but that is not my problem.
My problem is the format of the file to put in the idle url for a 7911.
rob.huffman Thu, 12/06/2007 - 16:26
Hi Met,
Here is the format for the 7911;
List.xml Example
URL="TFTP:Desktops/95x34x1/Mountain.png" />
URL="TFTP:Desktops/95x34x1/Ocean.png" />
The PNG files for background images must meet the following requirements for proper display on the Cisco Unified IP Phone:
Full size image-95 pixels (width) X 34 pixels (height).
Thumbnail image-23 pixels (width) X 8 pixels (height).
Color palette-For best results, set to monochrome (1-bit) when you create a PNG file.
(Cisco Unified IP Phone 7906G and 7911G)
Customizing the Cisco Unified IP Phone
Hope this is what you were looking for,
metalium2007 Fri, 12/07/2007 - 03:56
Thanks for your explanation, but, as you can see in my first post, i can insert custom backgrounds via list.xml, without problems. I can't use the idle url option in 7911, but i can in 7940/60.
Understood my problem?
