Change PIX 501 external IP remotely
Nov 29th, 2007
Hi all,
I have a need to change the external interface IPs on a number of PIX 501s from DHCP to static. As far as I can tell I would need to do the following:
Change IP address from DHCP setroute to static:
ip address outside
Add static default route out:
route outside
I need to do this completely remotely, with no hands on support available (multiple stores w/o any sort of IT). Due to how the sites are setup, I have to Remote Desktop into a PC, and telnet to the PIX, So I can't have any interruptions in connectivity during the process. I will be changing the IP from the DHCP assigned to the same IP, just statically assigned. Ex: DHCP assigns, I will assign statically.
I tested it in a controlled environment here at my DC. I started a ping from a PC connected to the PIX to the PIX's gateway (DSL MODEM). I am able to make the changes in the following order with not impact to the pings traveling out through the PIX:
insert static route
THEN change the IP on the outside interface.
wr mem etc.
Does this method look sound? Is there a better way of doing it? Is there a way I can just plop a different config into the memory, and reboot the PIX with the new config?
