How to do CAC between two Call Manager running SIP ?
Nov 29th, 2007
How to do CAC between two Call Manager running SIP trunk?
In the past, i can use gatekeeper to do call admission control using H.225 trunk?
I saw that rsvp is an option but if my WAN service provider does not support rsvp, what is the alternative ?
Aaron Harrison Fri, 11/30/2007 - 04:57
  • Community Spotlight Award,
    Member's Choice, May 2015
Define a location on both CallManager clusters with the bandwidth you want to use.
Set the SIP trunk into that location on each CallManager cluster.
You could get away with configuring this on just one cluster, but should really do it on both.
Aaron
Please rate helpful posts...
