Cisco CVP 4.0.2 - Data Feed Logger
Nov 29th, 2007
We have a Cisco Unified CVP 4.0.2 standalone deployment model with reporting enabled on IBM Websphere Application Server 6.1.
We observe the following CVP Datafeed logger error exceptions are written to Websphere logs -
C:\Program Files\IBM\WebSphere\AppServer\profiles\AppSrv01\logs\server1\SystemOut_07.11.30_07.32.32.log
ERROR (ServiceabilityManager.java:757) - DatafeedMgr.handleActEvent() e=java.lang.ClassCastException: java.util.HashMap incompatible with java.lang.String
[11/30/07 7:12:26:250 IST] 00000a10 SystemOut O [2007-Nov-30 07:12] ERROR (ServiceabilityManager.java:757) - DatafeedMgr.handleActEvent() java.lang.ClassCastException: java.util.HashMap incompatible with java.lang.String
at com.cisco.cvp.vxml.datafeed.DatafeedSessionVariableSet.updateSessionVariableSet(DatafeedSessionVariableSet.java:192)
at com.cisco.cvp.vxml.DatafeedMgr.processSessionDataSet(DatafeedMgr.java:2914)
at com.cisco.cvp.vxml.DatafeedMgr.handleElementExitEvent(DatafeedMgr.java:2196)
at com.cisco.cvp.vxml.DatafeedMgr.handleActEvent(DatafeedMgr.java:416)
at com.cisco.cvp.vxml.datafeed.DatafeedQueueThread.run(DatafeedQueueThread.java:71)
Please let me know how to make this appear only in CVP error logs rather than at the Websphere logs and help me to resolve this issue.
smalkeric Thu, 12/06/2007 - 14:33
  • Silver, 250 points or more
You may be hittng with a bug .You can verify the details of this bug :CSCsk29371
Sethuramalingam... Thu, 12/06/2007 - 20:11
I am not able to view the bug CSCsk29371. Could you please provide the external link to view the same or if you could provide details of what is the bug and details like is it fixed, verified and available version?
samkk2 Thu, 12/06/2007 - 21:08
Seth,
You can start with one of the following….
Load the Project into CVP Studio…
General Setting Page
Project Page
Logger section (add, Edit, Remove)
Edit (pick CVPDatafeedLog, from one of the (5) standard loggers)
check for plugins etc
AND/OR
Java class (JAR) specifying this standard logger “CVPDatafeedLog” should be made available to the specific CVP application in use. As such the location of the java class
for this logger can be changed to (sample application name used here…”HelloWorld”)
C:\Cisco\CVP\AppServer\applications\HelloWorld\java\application\classes
You could try to use the Admin scripts in the Admin folder e.g updateApp.bat or updateApp.sh (as needed with your system) to fix/update the java classes.
