Designing vlan
Nov 29th, 2007
What might be suitable vlan size i mean broadcast domain size. Howmany end users in one vlan. What is the basic risk of creting too big broadcast domains.
Overall Rating: 3 (2 ratings)
Jon Marshall Fri, 11/30/2007 - 00:42
Hi Juha
Different people use different guidelines but a commonly accepted size is a class C network ie /24. A lot does depend on the applications you are running on the vlans ie. if they use a lot of broadcasts to function then you may need a smaller size.
We use /25's per vlan where i work which gives 126 useable IP addresses.
The basic risk of too big a broadcast domain is that your clients spend too much time and resources processing broadcast traffic that may or may not be for them.
paul.matthews Fri, 11/30/2007 - 02:08
Just to add a little more t Jn's comment, keeping the subnet size small also helps should you have problems along the lines of code red or SQL slammer. Once a subet is identified as having an infected device, shutting down the VLAN as the first step before locating the infected device has a lower impact on other users - you are less likely to get grief for taking 70 users offline than if you took 400 users out for a single infected device.
Going for smaller subnets also makes the use of L3 links between switches potentially more practical.
