Many devices are partially successful in RME config management summary
Nov 30th, 2007
Dear all,
Many devices are partially successful in RME config management summary.It report error "CM0012: Unable to create new version on archive $1 Action: Check if disk space is available and directory has required permissions" How can i do?
Thanks!
dainat-bis Fri, 11/30/2007 - 05:28
It's the known bug CSCsh69403 in RME4.0x which is fixed in 4.1. The Workaround for 4.0x is to delete the device in Common Services and re-add it again to Common Services and RME.
cn1by080byj Wed, 12/05/2007 - 19:59
But we have so many devices,it is not been accepted that we delete them then re-add them.
Anyone have other suggestion?
Thanks!
