CE-1 recieves CE-2 routes but can ping them
Nov 30th, 2007
I am building a lab to simulate enterprise WAN would connect over MPLS cloud.
The problem is CEs receives the routes of each other, but can't ping any.
I have attached the config. file for the basic routers in the lab setup; CE-1, PE-1, PE-2.
Appreciate your help.
Sami
Overall Rating: 5 (1 ratings)
mheusing Fri, 11/30/2007 - 01:59
  • Cisco Employee,
you have to make sure to have MPLS enabled end to end between the two PE routers. So what is missing:
r7-PE1
interface FastEthernet0/0
ip address 78.78.78.7 255.255.255.0
speed 100
full-duplex
mpls ip
mpls label protocol ldp
mpls mtu 1512
r8-PE2
ip address 78.78.78.8 255.255.255.0
speed 100
full-duplex
mpls ip
mpls mtu 1512
Check your environment with "show mpls ldp discovery", "show mpls ldp neighbors", "show mpls forwarding-table". The latter should show you a "Pop" for the loopbacks of the other PE and some labels with a [V] for the VPN routes.
Hope this helps! Please rate all posts.
Regards, Martin
ccie16351 Fri, 11/30/2007 - 07:08
Hi Martin,
unfortunately, my current IOS image doesn't support "mpls ip/tag-switching'. Here it is
c3660-ik9s-mz.123-14.T7.bin.
Are you aware of an inmage can support it with 32F/128DRAM on 3660.
ccie16351 Fri, 11/30/2007 - 09:08
Hi Martin,
I managed to upgrade the IOS of the PEs to support MPLS, but problem still persist; CEs receives the routes of each other but can ping them.
r6-CE1#sir bgp
44.0.0.0/32 is subnetted, 1 subnets
B 44.44.44.44 [20/0] via 67.67.67.7, 00:03:02
r6-CE1#p 44.44.44.44
Sending 5, 100-byte ICMP Echos to 44.44.44.44, timeout is 2 seconds:
Success rate is 0 percent (0/5)
r7-PE1#sh run int fa0/0
Building configuration...
Current configuration : 136 bytes
speed 100
full-duplex
tag-switching mtu 1512
tag-switching ip
end
r7-PE1#sh mpls forwarding-table
Local Outgoing Prefix Bytes tag Outgoing Next Hop
tag tag or VC or Tunnel Id switched interface
16 Pop tag 88.88.88.88/32 0 Fa0/0 78.78.78.8
17 Untagged 10.10.10.0/24[V] 0 Fa0/1 67.67.67.6
18 Untagged 16.16.16.0/24[V] 0 Fa0/1 67.67.67.6
19 Untagged 30.30.30.0/24[V] 0 Fa0/1 67.67.67.6
20 Untagged 66.66.66.66/32[V] 570 Fa0/1 67.67.67.6
r7-PE1#88.88.88.88
r8#sh run int fa0/0
speed 100
full-duplex
tag-switching ip
r8#sh mpls forwarding-table
16 Pop tag 77.77.77.77/32 0 Fa0/0 78.78.78.7
23 Untagged 44.44.44.44/32[V] 1140 Fa0/1 48.48.48.4
r8#exi
mheusing Mon, 12/03/2007 - 05:26
  • Cisco Employee,
did you try an extended ping between CE Loopbacks? Might be that you use outgoing interface IP as source and do not announce the network. Did you debug ICMP on a CE (lab only) to verify packet (non-)arrival?
Could you also check on both PE routers:
and make sure CEF is working properly.
Regards, Martin
ccie16351 Mon, 12/03/2007 - 07:57
Thanks Martin,
I got working after I had the CE routers advertises the interface to their peers, in the bgp.
As usual, apprecite your help.
Sami
